Le fabricant hong-kongais 3Racing a annoncé une mise à jour 2.0 de sa version haut-de-gamme Cero Ultra-Ace.
Au programme:
NEW FULLY ADJUSTABLE UPPER LINK STYLE ARMS, ALLOWING FULL ADJUSTMENT OF CASTER & CAMBER ANGLE IN THE FRONT AND REAR OF THE CAR.
NEW NARROW (77MM) 2.0MM 7075 ALUMINIUM CHASSIS. FOR LESS CHASSIS SCRUB ON THE CARPET RESULTING IN INCREASED CORNER SPEED. ESPECIALLY IN HIGH GRIP CONDITIONS.
NEW 2.0MM ONE-PIECE TOP DECK WITH REVISED FLEX CHARACTERISTICS TO SUIT AN ALUMINIUM LOWER CHASSIS AND CARPET RACING.
INTEGRATED FRONT WEIGHT SYSTEM, WITH BRASS WEIGHTS WHICH ATTACH DIRECTLY TO THE MAIN CHASSIS PLATE BETWEEN THE FRONT BULKHEADS AND NEWLY DESIGNED FRONT LOWER SUSPENSION ARMS. GREAT FOR CHANCING THE FEEL, RESPONSE AND BALANCE OF THE CAR IN HIGH/LOW GRIP SITUATIONS.
QUICK CHANGE SPUR GEAR MOUNT.
HONEYCOMB TPU FRONT BUMPER INCLUDED AS STANDARD.
REDESIGNED FRONT LOWER BUMPER AND BODY MOUNT ASSEMBLY FOR INCREASED DURABILITY.
MOTOR MOUNT PROVIDES A WIDE RANGE OF ADJUSTABILITY TO CATER FOR ALL BLINKY MOTOR APPLICATIONS AND GEARING.
QUICK CHANGE BATTERY RETAINER SYSTEM, ALLOWS EASY TOOL-FREE BATTERY CHANGES.
ANTI-SLIP BATTERY CHASSIS PAD, PREVENTS EXCESSIVE MOVEMENT AND REDUCES UNSIGHTLY WEAR ON THE CHASSIS AND BATTERY.
ARS REAR SUSPENSION, FULLY ADJUSTABLE ADJUSTABLE TO ADAPT TO CHANGING TRACK CONDITIONS.
HORIZONTAL REAR BODY MOUNT SYSTEM, LOWERS CENTRE OF GRAVITY AND REDUCES BODY ROLL AND RISK OF BODY TUCKS.
Avec une boite de ressorts en cadeau pour ceux qui la pré-commanderont!
Source: [Limited Pre-Order] KIT-CERO ULTRA-ACE 2.0 COMPETITION GRADE TOURING C — 3Racingshop
